Daily Driver, Go Where I Want To Build
I need to do this. I got a generic washer fluid reservoir of amazon and the project stopped there. I would be nice to have this feature again.
This one gets a fiberglass hood. They are too thick for the OEM squirters to snap into so we use the aftermarket versions that have a threaded stem. The little nozzles are able to be aimed. But, they are not as efficient as the OEM version and need more volume out of the pump. We removed the OEM pump, added it to the generic reservoir and wired both to pump at the same time. Now it has enough volume.
How much of it is usable? With the leaky cap so low on the bottle - I'd venture a guess that you probably don't retain much of the difference you want with the OEM bottle in this configuration.
This rough line and above is unusable space (imagine a plane across the bottle intersecting here).
Your line is weird. The bottle is sitting nearly the same as factory.
Reactions: FarFire70
The ARB locker pump will live deep into the inner fender.
A comment on the hardware. I am using stainless with a black oxide coating for everything, all from McMaster-Carr. And following Blaine's previous work because it looks good and reduces visual clutter, all the bolt heads are facing the exterior, where possible.
You've got a small fortune into hardware, I bet.
Definitely a good call. The ones they include aren't long enough in many places so I had to run to ACE. Even so, I've found a few that have since worked loose.
The only two ways they don't work on the soft aluminum are using a nyloc or one of the serrated flange nuts and blue Loctite. Nothing else we have tried stays tight including Keps nuts which are generally very good. The visual aspect of a nyloc means it is taller and more obtrusive. The flange nuts appear less so.
Reactions: rasband
Halfway done!
A new mount for the purge valve...
...goes onto the inner fender before below the steering reservoir.
Talking to Blaine just now, I am going to replace the plastic emissions lines going to the purge valve with silicone vacuum line to improve the routing and eliminate the side loading from the hard plastic.
Halfway done!
There's some nice glitter down there, Mike will be proud!
Looks good :) I really like the color matching you did!
I'll guess about $175 and with minimum quantities of more than I need for this project.
Yeah, the per piece cost is low, but when you end up with 25 bolts when you only need 5, you end up with quite a collection. I Had to buy a storage locker to contain all my nuts and bolts!
Halfway done!
I got two things mounted today.
The winch contacter is back behind the headlight again.
With it and the battery in different positions, I need a longer positive lead.
Fortunately, I still have the new leads from when I changed from solenoids to a contacter a couple years ago. This one is too long. That's a tomorrow project. And will be the start of eventually replacing all the battery cables.
And I got the onboard trickle charger hung behind the PDC. No pics. That all came together as daylight faded and I wanted to get the day over with.
Highlines are not easy!
On the topic of refreshing the battery cables, I wouldn't mind clamps that have individual terminations rather than stacking ring connectors.
Any thoughts on this type of distribution block?
The screws on the sides seem useless. I like the idea of the top though. I’d like to see something similar but better.
Reactions: AirborneTexasRanger
