2002 Wrangler X
4.0L with California emissions setup
Engine is basically stock minus a few replacement parts that are fairly trivial (coolant/heater hoses, couple of wires replaced, a few vacuum lines, etc.).
The P0135 code just won't go away and bank 1 fuel trim is crazy high (>+30 at idle; drops to 0 when held at about 2000 RPM for a few minutes) but bank 2 looks fine.
I'll list the things I've done so far:
1) Replaced 1/1 sensor (yes, NTK) as the heater element had slightly out of spec resistance; seemed like it's the most likely culprit but didn't change anything else.. Cleared codes, it came back.
2) Traced all wires from PCM to all 4 sensors; all 4 sets of wires had less than 1 ohm resistance between when appropriate and were otherwise not shorting to ground, etc. (per service manual 8W-30-13). A couple of the wires on C2 (black PCM module) looked damaged, but it was superficial to the coating, nothing exposed; rewrapped the harness)
3) Checked spark plugs. Spark plugs 2 and 3 were pretty dirty, probably from running rich, replaced them. Cleared codes, P0135 came back
4) Compression check of the engine; all 6 cylinders were fine.
5) Checked other O2 sensors; 1/2 sensor is basically still the OEM one, so I'm replacing it, new one on order; figured may as well replace all 4; went ahead and ordered the other 3. Should be here this week, but still no clue on how that might impact the p0135 code.
Next docket item:
Replacing sensors 1/2, 2/1, 2/2 (they're all old, probably due anyway), but I don't see how that could cause a P0135 code unless 2/1 upstream was shorting to ground on the F142 wire (which it wasn't).
Per other forum threads, I've surmised a vacuum leak may be the culprit and will replace all the vacuum lines anyway, but I have yet to find a leak and I also don't see how only bank 1 would be impacted.
Any ideas on this one would certainly help as I'm about tapped out on them.
Next docket item:
