Problems with Cerakote Trim Restoration
JasterMereel42
Out West
I've heard good things with Cerakote. Lots of people have said that it is the best way to restore the gray faded fenders on the TJs. I applied it and here is what it looks like.
1. The front fender has Cerakote. It is still grayish and very streaky.
2. This is the step under the door and this looks great!
3. This is the original color of the fender.
4. Side view of everything together.
Like I said, that front fender that's been treated with Cerakote looks better, but still doesn't look great. Should I use a different product on the other fenders? Or is there something that I can do with the Cerakote to make it better? It is definitely darker, but has lots of streaks in it. It looks OK, better than it did before, but still not great.
Anything else I can do?
I dont know why so many recommend it and other oil/waxes or heat when a can of spray paint is a few bucks, is applied in under 30 min per flair without removing them, and lasts for years
Reactions: Shank
If you don’t mind putting a little bit of work into them lightly sand the fenders and slap a few coats of krylon fusion paint.
I did this to a set of Bushwacker flares when I had my YJ in Hawáii and held up great before selling it a year or so later.
Cerakote what? When I see the name cerakote, I think guns and a very hard, baked on ceramic finish. That's obviously not what we're talking about here.
There are also air curing formulations of cerakote. Its less durable but actually higher temp, making it good for parts like silencers.
Just washed them.
You need to wash them, then make sure they are completely dry, and one final step is to give them a wipe with isopropyl alcohol to make sure the surface is completely clean. My guess is there may have been some moisture still on your flares which caused the streaks. It's also possible that your flares were bleached beyond being restorable. I had an Xterra that I used cerakote on with good results, those Xterras have a ton of plastic.
Reactions: Artsifrtsi
I believe you mean "ceramic"?
Yeah, that looks like shit.
I started using Chemical Guys ceramic trim restorer, night-n-day difference over f11.
Most recent, mines the better looking TJ.
Nice dark with no greasiness.
Reactions: AndyA
