Steering wheel won't align. Easy?
LittleGiant
Honolulu, HI
Recently had an alignment done and the steering wheel was at 8 o'clock and 2 to stay straight.
I was told it’s because I have slop in somewhere. Didn’t make sense because I just replaced the steering gearbox along with upper and lower steering shafts.
This to me seems like an easy fix. Disconnect the drag link, straighten the steering wheel and adjust the tie rod end of the drag link then reattach. Now it’s tilted the other way. 10&4.
What did I do wrong?
yes, loosen the 2 clamps, give it a turn either direction, take it for a ride and see which way it moved. then repeat till you get it where you want it.
I've found it easier to adjust by placing a piece of tape at top center of the steering wheel. Then you can make your drag link adjustments and stand up to to see if your getting close by looking at the tape on the steering wheel.
Well I guess I made it harder than it needs to be. Haha. Seems even easier now. Will get on this once I’m home from work
Technically, leave the Jeep running in park while you make your adjustments with the sleeve. As you turn the sleeve the steering wheel will turn one way or the other. Once you know which way you need to turn it do it till it’s just shy of center. Then tighten up and go for a drive and see it’ll it’s really straight. Come back home and do it again till you get it just right. Can take several attempts.
Brother I probably went up and down the road adjusting my drag link at least 5-6 times before I had it right.
Reactions: tr21triton
Ok. Good to know it’s an easy process, just a little tediius
Yep. You don't need an alignment shop either. All you can adjust on a stock TJ (or one with a shorter less involved lift) is toe and steering wheel alignment. Such an easy vehicle. The tire guys don't want you to know that though. I had to fight them to balance my tires properly because "balance can't cause death wobble". I digress.
