When I sit in neutral and rev the engine, the rpms take a second to go back down. All i do is press the gas once and take my foot off and the rpms don't fall back down instantly, is this normal?
yeah the wires are from me, I've been too lazy to mount my mechanical oil gauge. It doesn't do this all the time, i'll get another video of the dash this time. Do you think it has anything to do with my transmission or clutch? I replaced the throttle body like 2-3 months ago with one from a 4.0 and bored it out. It also has a throttle body spacer.I dont know about the rpms, but the wires hanging aint normallubricate the throttle linkage, look for corrosion, an clean out your throttle body.
Clean the IAC, put the stock throttle body back on, and like @Chris said, take the spacer out.Take the throttle body spacer off, those don't do anything on a modern fuel injection engine.
Was it doing this before you replaced the throttle body? I would try cleaning your IAC first off.
the throttle body has been on there for a at least 7 months, I just like the sensitivity of the throttle.Take the throttle body spacer off, those don't do anything on a modern fuel injection engine.
The throttle body spacer and 4.0 throttle and stuff has all been on there for a while, this rpm hang is recent. However I just got a cold air intake like 3 weeks ago, could that be doing it?https://www.carsdirect.com/aftermarket-parts/performance-accessories-throttle-body-spacers - if you added more air, maybe its takin more time to wind down, were their any springs on the linkage that you strecthed, changed, when you added the spacer. is it the right bore an spacer for the motor. were there any other adjustments needed when you added the spacer? did it do it before you added the spacer, an trans work? if its doing it not in gear, I am not sure how it would have anything to do with the transmission, unless, they adjusted it when they did the work on the transmission, or bent the linkage. is the clutch bracket the same as the gas pedal bracket? that could have gotten bent? I had a steering line on a jet ski i had to replace cause its just old, an hanging up, an corroded, inside teh sheath. get a video of the linkage under the hood working, an underneath the dash of the pedal working. lubricate the movement points of the gas pedal underneath, without getting it on the gasbrake or clutch pedal. is there any air getting past the gaps in the throttle body spacer when say the jeep is on a different grade of ground. do you put anything in the gas, on a normal basis or at different times. do you same octane gas at every fill up?![]()
Nope, just trying to make sure anything that exists doesn't have to do with the transmission seeing as I paid 2119 dollars for someone to fix it and got it back fucked up with an idiot trying to convince me that when my car wouldn't go into 5th gear was because it had to be worn in. I'm not going to let anything slide for them as I am going there with a list of things they need to check or i'm going to sue them. The wires go to a mechanical oil pressure gauge which has nothing to do with the transmission. Just because you see wires doesn't mean squat. If you really think there's nothing wrong with my transmission because there are bare wires, then i will bet you 500 dollars to come drive my jeep and tell me the transmission feels perfect. The transmission shop takes the jeep back and works on it every time because they know something is wrong with it.Seeing that video and the wires hanging down etc makes me wonder if you've been blaming the transmission shop for lots of things that have nothing to do with your transmission
Nope, just trying to make sure anything that exists doesn't have to do with the transmission seeing as I paid 2119 dollars for someone to fix it. The wires go to a mechanical oil pressure gauge which has nothing to do with the transmission. Just because you see wires doesn't mean squat. If you really think there's nothing wrong with my transmission because there are bare wires, then i will bet you 500 dollars to come drive my jeep and tell me the transmission feels perfect. The transmission shop takes the jeep back and works on it every time because they know something is wrong with it.
I don't just have 500 dollars laying around. I have a full time job and school. On top of that I parked my friends car and it got towed, my plate is due for a renewal, I have 2 dogs that need a vet appointment, and I lost my wallet with 100 bucks in it. I don't have time to bring my car to other shops to have it looked at. Also I just moved to where I live right now and don't know any shops around here. The transmission rebuild has a year warranty and it is drivable so until I get on summer break I really don't have time to bring it in anywhere. Sorry if I was upset but this transmission is genuinely fucked up and I couldn't even afford the rebuild to begin with. I just don't have time or money to keep investing in this issue when I paid so much to have it fixedIt's been a super long time (weeks) and several pages of posts and you still haven't taken your vehicle to a different shop to have it "fixed".
Hate to be a skeptic but just sayin'....
Why not put that $500 towards a diagnosis .
