I'm sure this is already been asked, but, on my 2006 Wrangler 4.0 with an auto transmission. Transmission is going into high temp mode and shifting rough. ECM / TCM has been sent to SIA and they said there must be a short. Local transmission shop said the same. Wondering if I need to pull the loom off of all of the wiring or if someone here has had the the same issue. Wondering if it's a sensor or the solenoid. Thanks for the help. Will hook up the OBD and check codes.
