On most driving my oil never gets much over 170 degrees. When idling I can get the temp up to 185. Tested this all this month with a GlowShift oil and temperature gauge.
Granted where the "temperature" is being read is straight out of the oil pan.
If I saw those results I'd want to try a different sensor.
I say that because this is the first time I've seen results like this shared by someone with a 195* thermostat and also because my IR thermometer puts the pan temps around 250* near the pre-cats, and 180* & 190* in other areas after driving for 5-10 minutes going between 25-45 mph.
@macleanflood it's very possible that your numbers are correct. My eyes and ears are open on this one. I'm curious to know what your pan temps are with an IR thermometer as the oil in the pan could be cooler than the pan temps.
Note: My temps were taken in 79* ambient last night with the engine off, and the initial reading of the pre-cats area was much higher from the radiation (336*).
