I stopped at Orlieys to have them look up the reason for the check engine light that came on two days ago. It said (check gas cap) or Evap system leak (small)... I am pretty positive I know what it is. And I am feeling really stupid, because it's my fault...
I didn't notice the disconnected vacuum line (going into the firewall), and I tried to charge the AC. I tried to use the O'riley rental kit & the basic cans (even after a lot of research/YouTube I still manage to struggle with the "filling part" -( is it getting refrigerant in, sort of guessing...) Anyway, I just gave up and returned the tool. Then, a few weeks later, I found a section of the vacuum line missing, I put in some tubing & clamps, and The air starts blowing about the vents much better (still not cold, just improved blowing). I pull a vacuum & it's NOT holding a vacuum. This is where I should have stopped and figured out what to do. But I put in some refrigerant and then took it out because the pressure was still high.
So I just returned the tools and figured it would have to wait. I guess that was a mistake, leaving the pressure high ( I made sure to not have the air on at all, so I was hoping that would keep it okay until I got it fixed.
The other day I noticed a hissing noise from the hood after a drive. I open it up and the radiator has a tiny crack on the top, coolant sizzling. SO I'm guessing this is the cause of the check engine light.
Hopefully I can get some helpful adcice, 1. how do I relieve pressure from the system? 2. Is there anything besided the radiator the may be damaged to the overpressure? do I fix pressure/jb weld small crack/refill radiator. OR Do i fix thehigh pressure and then replace w/ new radiator?
