Hiya guys !!! Remember me ?
I have a question I think I already know the answer to but I’ve learned these TJ’s are finicky bitches. I’m pretty sure I’ve developed the common exhaust manifold leak. It’s not huge but I’m pretty sure that’s the new undiagnosed noise from the nether regions on the engine bay. Here’s the question. Lately when I first crank the jeep it runs rough, doesn’t want to idle and usually takes a few good rips on the ol go faster peddle before it clears up and she runs right. I’ve replaced the entire fuel system from pump to injectors so I’m not really thinking leaking down fuel pressure or such. Could the crack in the manifold be causing the issue ? I’m gonna replace it regardless with a good quality aftermarket header (no for performance but for just a stronger sturdier part than the stock prone to crack manifold) but I’m curious if this will fix my cold engine idle issue or if I should be looking deeper. I’ve already scanned her and other than the same EVAP code it’s had since I bought it there’s no new codes. Just wondering what the brain trust here thinks.
