Does anyone have a rear bumper from Bulletproof Bumper Mfg? This company has been defunct for a decade or two. It's a shot in the dark but I'm looking to get their basket that goes over the spare tire.
Would you happen to know what brand of Jerry cans that work with the rear bumper set up?Does anyone have a rear bumper from Bulletproof Bumper Mfg? This company has been defunct for a decade or two. It's a shot in the dark but I'm looking to get their basket that goes over the spare tire.
Blitz or anything that has a lip along the bottom perimeter of the can.Would you happen to know what brand of Jerry cans that work with the rear bumper set up?
@ChrisTJ98 I loved those bumpers, I sold them with my last jeep it went to Louisiana ironically. Those bumpers took a beating this is the best I could do, If I find any more I'll send them your way. Looks like a piece of half inch bent 90 and welded on. There there was no bushing just the gate clamped right to the L bracket. If I remember correctly where the U bolt attached to the L it had a bit of a valley so it nested in there when clamped.
Thanks, you wouldn't happen to remember the spacing between the cross member and the bumper itself would you? it looks like maybe a 1-1-1/2" spacing possibly. I decided to just build a new bumper I ended buying a latch from E3machine probably paid to much but it looks like the highest quality compression latch I've ever seen and should last I hope another 20 years.
The space between the bumper and crossmember needs to be wide enough to insert the length bolts you intend to use and the tool you intend to use to hold the bolts.
I'm going to thread it into the backside of the bumper like bulletproof did, so that's why I'm curious as to what is the spacing they used.
@ChrisTJ98 So after thinking about it for another min I do remember the U bolt being very close to the tub when I'd latch it. The Ubolt itself is 5/16 I just measured it, then I had 3/16 body armor as well. So that's a half inch right there plus the thickness of the angle stop and now you are at an inch so it would have had to been at least one inch one quarter minimum or the latch would have not been able to operate.
I ordered the spindle style hinge from EMS as well and these two plates from Taboo Customs https://taboocustoms.com/store/TJ-Rear-Bumper-Tire-Carrier-Mount-Kit are 1/4" thick that is the same bolt pattern that the TJ cross member has and is the same as what bulletproof manufacturing did but I think they may have used 3/8" plate so I would have at least 3/8" gap between actual bumper and crossmember currently. I reached out to another company that makes swing out tire carriers and they told me using 4"x2" rectangular tubing and the swing out tire carrier that I would need no less that 1-1/2" gap between bumper and crossmember. I do want to keep this close as I can to the crossmember but a little gap I think is good. I'm just real picky on the way some manufactures mount these bumpers. I just want a clean look about it. I do think I am going to need more than what I currently have to mount a highlight jack if I ever were to buy one. Its good to brain storm and ask lots questions. I'm basically just taking little ideas from everyone out there that makes bumper and trying to put it into something of my own that is a clean look.
Thanks
Taboo is a good company to work with, I had him custom CNC me some rear frame sections for my LJ when I was rebuilding the frame. You should keep this thread going to bounce ideas around. I'm going to try and build off of a Warn bumper at first If it doesn't look like it will work out I'll go full custom.
If you really want the absolute details the guy I bought my replacement engine from has a pair of said Bulletproof bumpers on his LJ. He's not that far from me and I'm sure he'd have no problem with me coming up and taking measurements, I'm still in contact with him. And no he doesn't want to sell them I already asked. I think he was a little stunned when I called them out he just kind of gave me that blank stare for a second.![]()
Can I see a closer up picture of the Locking mechanism and the hinge point? I have a bulletproof rear bumper and finally after all these years I want to go with 33" tires but I want to to build a tire carrier off the original bumper.
Thanks
Chris
