97 Wrangler Sahara:
For several months the volt gauge would go way down at idle but would go back up if I raised the rpms. A friend told me it was probably a bad diode. Driving yesterday the volts dropped all the way to the bottom. When I got home and turned it off and restarted it the volts went back up but after a few seconds the volts went back to the bottom again. I put a volt meter on the battery. It read 12v. I started it up and the volts showed it was charging but dropped off after a few seconds. I understand the voltage regulator is in the ecm. How do I check which is bad, the alternator or the cem??
