Hello everyone, I’ve been a guest member for a little while (I’ve been looking at posts, I just never created an account)
I bought a 2001 Jeep Wrangler 4.0 Auto trans, I have a problem every time I accelerate hard and then do a completely stop. I did some research and I saw it’s called “limp mode”. But it throws me P0300, P0303, P0304 and it doesn’t rev over 3000 rpm
Someone told me that if I remove the upstream O2 sensors then it can be the catalyst converter being clogged. So I did that and the Jeep was running better, only thing is that it sounded like a straight pipe truck.
I changed the catalyst converter for a Flowmaster catalyst converter that I bought from Amazon, and it still gives me the same problem and same codes. (If i remove the O2 sensors it runs fine) I changed camshaft position sensor and throttle Position sensor.
Every time i turn off and turn back on the Jeep, the problem disappear but appears again once I hit the gas pedal again.
I really would appreciate any kind of help.
Im uploading a video of the problem I have.
