I woke up this morning to head to work, and Jeep started horribly. I've never heard it start like this. It's a 05 Unlimited with 76k miles. It's had a check engine on for a while due to a bad O2 sensor. I have been using another vehicle so I was putting it off as it was driving fine. However today, it was not. I believe it's gone in limp mode, it idles very rough, however, the transmission seems to be shifting fine. It almost doesn't wanna start when I turn it on.
Anyways, the check engine light started to flash after driving it to work. Fortunately, I had just gotten to work. I plugged in my scanner to check what codes I was getting, to find that I now have 7 codes.
P0300 (1/7) Pending
Random Misfire Detected
P0157 (2/7) Stored
O2 Circuit Low Voltage
P0161 (3/7) Stored
O2 Heater Circuit
P0057 (4/7) Stored
HO2S Heater Control Circuit Low
P0700 (5/7) Pending
Transmission Control System (MIL Request)
P0157 (6/7) Pending
P0161 (7/7) Pending
O2 Heater Circuit
I am assuming the transmission code could be due to the Jeep going into limp mode, however, I am not sure if a bad O2 sensor can cause this, in which case I would be really confused as to where to start. All codes coming on are for the O2 Sensor Bank 2 Sensor 2. I am going to replace that tonight but was hoping any one could give me any insight or tips that may be useful.
Thank you!
P0300 (1/7) Pending
P0157 (2/7) Stored
P0161 (3/7) Stored
O2 Heater Circuit
P0057 (4/7) Stored
P0700 (5/7) Pending
P0157 (6/7) Pending
P0161 (7/7) Pending
O2 Heater Circuit
Thank you!
