Plow counterweight ideas?
CreepinDeth
Midwest
Put a Western Unimount on the TJ
Also have new airbags up front.
This is an all new 2.5”suspension too
Tried it out for the first use yesterday, and discovered that I need a counterweight. New doubled driveway has a new section that is higher then the ground and my plow went off the edge and I nearly got stuck. That tells me my ass end is unloaded a bit, and traction isnt as solid.
Have some A/T chunky Coopers on it too, but I had a few “sit n spin” moments which made me realize if I went off the edge completely I wasnt gonna recover it even in 4wd
Anyone have counterweight ideas / experience??
The pallet was just there after initial install, got the chain readjusted and now its level with ground unloaded in float and aired up the bags
Maybe this is why Jeep says don't put a snowplow on a TJ.... That said , most 3/4 -1 pickups should have 800 lbs. counterweight at the rear of the truck .
You could get multiple 3/8" steel plates made to fit in the rear of the Jeep and stack them as needed to achieve your goal . You will likely need to beef the rear suspension quite a lot .
Reactions: CreepinDeth
Yeah I dont wanna put salt on my driveway, but I could probably mount some kind of fabricated box and fill it with rocks
looks like Im gonna have to buy rear airbags also after all
First year I will get all the bugs worked out
Reactions: macleanflood
I didnt get that memo
Most people are quitters
What class of hitch is this on the Jeeps??
Im tryin to figure out the tongue weight it can handle
The LJ was rated for 3500 lbs towing and 350 lbs tongue weight. The same receiver and attachment method is used for both the TJ and the LJ. So as long as your lever arm isn't too long, 350 lbs should be feasible.
You might consider a hitch mounted crane. It'll lift the rock, provide your counterbalance and you can use it for lots of other shit.
This is the perfect solution. Use a hitch mounted crane to load boulders into the back of the Jeep to act as counter balance for the snowplow.
True
Its a guessing game of tongue weight leverage increasing too tho, which is the wild card of unknown I would imagine
Look how far ahead of the front axle centerline your plow extends , and what it weighs. You would need to equal it off the trailer receiver , that will be a Long extension and a lot of weight dangling off the rear of the TJ.
You Jeep is going to get real long and real heavy , and way above the GVWR of a TJ.
Not too concerned about that ^
The TJ is exclusively in winter driveway plow mode
The new driveway was too big to snow throw so I literally just got the plow to do my driveway. We have plenty of DDs and other spare vehicles for actual roadway usage. Once winter is over, the plow will come off, and we will throw the TJ back in for a summer toy
If I blow the new shocks doin just that, whatever I will buy new ones. im def not doin a crane off the rear, first thing I thought of was swingin. I like the sandbags idea too
