HOW TO GET MORE PRESSURE OUT OF AN ARB SINGLE MOTOR COMPRESSOR (CKSA & CKMA)?
ARB CKSA and CKMA Air Compressors include a pressure switch that regulates pressure up to 100 PSI; which is all you need in most cases. However, if you’re looking for slightly faster Air Locker engagement, need to inflate past 100 PSI, or if your air tools require more pressure, there is an alternative. The ARB Twin Compressor (CKMTA) pressure switch can be used on the smaller compressors. Simply order ARB part #
180901, install it on your ARB CKSA or CKMA Air Compressor, and you will be rewarded with an output of 150 PSI.
