With both front fog lights disconnected, my 20A fuse keeps blowing upon switching on lights at multifunction switch at steering column.
The hi beams are NOT engaged. Assuming the problem is somewhere between the switch and the fuse/relay block. Usual suspect: Twist/pull switch mechanism?... But NOT the relay?
