H&R 52107 1" Spring Lift with Rancho RS5000X 0-2"
smanchur
British Columbia, Canada
Hi all. I thought I would share my results after installing H&R 52107 1" Springs. Since before and after questions are quite common with this setup, I thought it wouldn't hurt to share some more results. All components were completely factory before lift. 2004 Jeep TJ Rockey Mountain Edition. Tires before and after are the same KO2 235/75R15. In addition to the spring lift, I decided to tackle everything in the suspension and steering in one shot since all components were original and bushings were looking tired. Parts replaced:
Suspension
  • 1” lift coil springs all around - H&R 52107
  • Coil spring isolators all around - OE (Original Equipment) Moog
  • Bump stops - OE Dorman
  • Rancho RS5000X shocks all around - 0-2" option
  • Upper and lower front control arms - OE Moog
  • Upper and lower rear control arms - OE Moog
  • Front track bar - OE Moog
  • Rear track bar - OE Moog
  • Sway bar bushings front and rear - OE Moog
  • Front sway bar links - OE Moog. In hind site, this is the one component I wish I upgraded but did not, with JKS quick disconnects. Can still be done very easily if I find is necessary.
  • Rear sway bar links - OE Moog
Steering
Jeep ZJ tie rod upgrade. Thicker component upgrade. Simple bolt on replacement, no modifications needed. Photo provided from another thread.
  • Moog ES3096L – upgrade left outer tie rod
  • Moog ES2079S – adjusting sleeve
  • Moog DS1312 – upgrade left inner tie rod
  • Moog DS1430 – OE TJ draglink / connecting tie rod
  • Moog ES3096L – OE TJ tie rod end at pitman arm
  • Rancho RS5000 steering damper
Results
Front 1-1/4"
Rear 5/8"
Front Bumper 1-1/2"
Rear Bumper 1/2"
Before
Take notice of the Pepsi cans.
After
The Jeep nearly sits level now. Rear seat in with Bestop soft top both before and after. No additional weight.
I have only driven for roughly 15km (Canada) since the upgrade. Very minor off roading for a few km only so far, but initial impressions are a nice improvement in feel.
In the next 1-2 weeks I'll be able to climb some hills and really give it an off road test to see how much is improved.
I will almost certainly be going to a larger 31x10.50 from the current 29" tire in the coming months. I want to ride on the same tires for a while first to really get some perspective on suspension only differences over factory.
Thanks for sharing your results. You mentioned that you had a nice improvement to feel. Do you know what shocks were replaced with the Ranchos?
Nice looking jeep btw
I have yet to do the ZJ upgrade, but the rest of your work was basically the same as what I did with similar results. I too skipped the JKS disconnects, but probably will get them eventually. And I also replaced the swaybar bushings with the Moog product, front and rear. Thanx for the VERY nice and clear pictorial - it helps!
Reactions: ColoJeep
The previous owner had KYB shocks on there. I estimate they looked 10+ years old and were probably a little worn out.
How do the Moog replacement control arms compare to the OEM ones? Several of the replacements I have seen appear to use thinner metal than OEM.
Moog is generally very good product. In my experience they don't ever make a part of inferior quality to OEM for any vehicle. These controls arms seem to be good quality, but I did not take a close notice to the metal thickness vs the originals. The originals are gone now so I can't compare at this point. Sorry.
Reactions: zackcj7
Love the same H&R 52107 1" Spring Lift with Rancho RS5000X 0-2" on my Wrangler. It sits perfectly, and my 30" General Grabbers are closer to most advertised 31" tires, so it's a perfect combination.
Pretty sure they're the same.
Reactions: Oberst Oswald
All this time I finally found the beginning of your Jeep build page. I usually land somewhere in the middle and slow going following next page without knowing what is next. Going back would take me to your dancing pages. See the index now. Thx for the H & R page.
The index for the Jeep page is literally at the bottom of every post I make. Just sayin'... ;)
  • Face Palm
When I bought my moog replacements a couple years ago,they didn’t make the problem solver heavy duty ones,so I kept mine to replace the bushings when the others go bad,my originals are much heavier metal.
Don't know why I never clicked on it = 🦤. Oh wait.. think I got it... was my subconscious protecting me from seeing any male belly dancing 🙈.
Reactions: Zorba
You know... I'm trying to think of something clever and creative to say but I'm lost for words... just watched Mary Jane's Dance 11/2024 & Oracle of Flow 11/2024.
If you mean the Oracle of Flow "Cartouche" performance, it wasn't my best by a long shot. Blundering around looking lost for part of it. "Pirates and Sirens" is a better one by the same group. The solo "Mary Jane's Dance" is my "signature" dance, for whatever that's worth. Its dedicated to the late Mary Jane Skopos, my very first costume lady who passed through the veil in July of 2002. I'm certainly NOT the Goddess's gift to the art-form, but I have fun. Congrats on being brave enough to check it out!
Yup it was "Cartouche". When I seen the word "Car" thought it was you belly dancing around your Jeep. Was quite surprised when I didn't see the Jeep or the you I was expecting...
Reactions: Zorba
Yup it was "Cartouche". When I seen the word "Car" thought it was you belly dancing around your Jeep. Was quite surprised when I didn't see the Jeep or the you I was expecting...View attachment 585535
Hmmmm.... Maybe I should do a Jeep/Belly Dance video... I'll have to noodle on that a bit - I'm sure it would be a hit with forum regulars! ;) :D
But in the meantime, this oft-posted picture will have to do - and it isn't even Belly Dance related:
Try driving a TJ with an updo and bustled skirt sometime. In heels! Wearing a corset. The experience was rather "interesting"...
  • Love
