Tried search ….couldn’t find the answer.
55037653AB has hose barb fittings on the radiator for automatic transmission cooler lines (97-04)
55037653AC has quick disconnect fittings for automatic transmission cooler lines (05-06)
Every old post I see has people finding and modifying an “AC” model for use in a pre-2005 by adding Hayden 397. I need to go the other way for a 2006 —- “AC” nowhere to be found but did find an “AB”. I want to modify the AB (97-04) from barb style to quick disconnect fitting (05-06).
I’m told the Dorman 800-605 often referenced will not work with an OEM mopar radiator. Is my only option to attempt removing quick disconnect fitting from the old radiator or can new quick disconnect fittings be sourced that can be easily installed without modification?
