I am the owner of a 2006 WRANGLER RUBICON TJ with a 4.0L engine and a 42RLE automatic transmission, with only 27,000 miles.
For the past few months, my Jeep’s transmission has been going into “Limp Mode”, usually when in fourth gear, after approximately one hour of driving. When this happens, the transmission gets stuck in second or third gear until the error is cleared and the check engine light turns off.
The error code that appears when scanning is P1776:
“IGNITION RETARD DURATION FAULT. Solenoid switch valve latched in the left rear position; ignition retard.”
I have already tried everything that has been recommended, but the problem persists:
1. Transmission fluid level check – OK.
2. Inspection of the entire electrical wiring – Done.
3. Replacement of the complete solenoid pack – Installed a brand-new one.
4. Replacement of the PCM – Installed a new one from Wranglerfix.
One additional detail, which may or may not be related, is that this issue started occurring after replacing the engine cooling system radiator with a used one that appeared to be in good condition.
I am running out of ideas and would greatly appreciate any input from the experts in the group on what else to check.
