Speed Sensor Connector
Fred97TJ
Canada Quebec
Hi,
It's my first post on these forums, so if I'm not in the correct place, please excuse me, I'll try to get in the right place next time!
I'm just starting to get into Jeeps, got my TJ about 5 months ago. Planning on doing a Teraflex sye kit so that I can remove the skidplate spacers and I'll be regearing from stock 3.07 to 4.10 gears. I bought a SpeedoDRD corrector, but the wire is pretty short on it and I don't want to leave it on the underside of the Jeep. I'm trying to find the Speed sensor connectors to make an "extension harness" so that I can relocate the corrector either under the dash or somewhere on the firewall.
I can find the female side of the speed sensor connector, but I can't find the male side. Does someone have a part number for me so that I can find this connector to make my extension?
I would need the same connector as the one shown in the picture.
Thanks for any of your help!
Any other ideas are well appreciated!
The connector on the sensor is a 3-pin Aptiv Apex 2.8 Series Male Connector. There are two different part numbers for it: 54200312 or 15394689. It uses terminals that are part number 54001801 or 10762775 (again, two different part numbers, but the same part.)
The connector on the harness is a 3-pin Aptiv Apex 2.8 Series Female Connector. There are two different part numbers for it: 54200308 or 10757671. It uses terminals that are part number 54001800 or 10757690.
I think there are two part numbers for each component because Aptive changed part numbers at some time in the recent past. Sellers seem to use either one interchangeably.
The Christmas tree connector on the male connector in the picture above is Aptiv part number 54200010.
I recently bought some of these from Waytek. I'm not sure who sells these in Canada, but Google will likely get you there.
Mouser sells these too, under the 1xx numbers above. I don't know how their shipping to Canada is.
That's exactly what I needed. Thank you very much! Part numbers and all everything is there!
Seems like Mouser has a Canadian division, I'll see what their shipping is, but I may be able to get them elsewhere. Thanks!
Reactions: sab
