Chalk test
tjstellar
Florida
Just have a quick question. Just installed 31x10.5 on my stock tj. My chalk test on all 4 tires show wear even throughout middle and inner yet the outer edge of the tire has chalk on it 29Psi
I don’t have experience doing chalk tests but I can tell you that the front WMS is set to have a slight negative camber (wheels tilted inwards at the top). So intuitively I would expect similar results from the front tires. As for the rear, maybe they have just been rotated front to rear and show the same wear. I’m not 100% confident on this though.
They are actually freshly installed. Not sure if it's the tire design or just too much pressure but the inside and middle are even
I just use chalk to draw on the sidewalk, so I am no expert. But maybe put some attention to this failing part.
