Frame Work underway.
I still see dried mud under your rear fender flare. :unsure:
p.s. Are those 33s or 35s? I'm thinking of dropping down to 33s.
33 discovery STT Pros. Just put my second set on a week ago. 1st set lasted 4 years as DD and weekend warrior. Beat the tar out of them and never let me down, or got stuck.
I should update a few of my pics.
My ole Jeep started experiencing extended/slow cranks and intermittent no power at key on this week. Ended up being the shoddy battery terminals the PO had installed. The positive side clamp started backing off the wiring, after repairing it everything started working perfectly. Now to wait for the JeepCables Big 7 package to arrive so I can just replace all the wiring in one go. Seems easy enough, not like the battery cables I used to replace as a recall on the GMT10XX trucks.
For those wondering, this is what kind of terminals the PO installed..... the stupid plate is bent to all hell and making a poor connection, ended up slapping an ring terminal on it and connecting it to one of the screws so I could get to work and back while my package is lost in the land of Oregon.
Recently, have done a handful of small things like aligning the new headlights, getting the air box mounted probably, painting up a patch of rust I ground down while fixing the brake line retaining bolt.
Bought the shocks to get the ball rolling on doing a lift!
And getting all the supplies to do RMS repair on my wife's Jeep this next weekend
Reactions: SouthernLJ
