I just installed the Zone 4.25 combo lift and went with the Zone sway bar disconnects. How long should the discos be once installed? The directions say to run them all the way tight and just make sure both sides are the same length. It was kinda tuff getting them on the pins the first time. I saw with the BDS brand they tell you to make sure the sway bar is at a 10 degree angle, and to adjust the discos accordingly to get that angle.
