Death wobble at 45mph
cehernandez
california
Jeep Tj 2004 2.4l 130k miles.
So far I've installed a 2.5" JKS lift kit that includes an Adjustable Track bar, quick release sway bar linkage, a 2" rear track bar adjustment bracket.
I also got the jeep aligned, tires balanced, Steering Stabilizer changed.
What do i need to replace to have this issue gone? Is it my ball bearings?
Learn from my misery.
Reactions: cehernandez
I'm getting a RockJock Steering system, the guys in the reviews talk about house it eliminates the death wobble. One guy even saying he no longer drives in fear. I'll be hopefully installing it this weekend. I'll also be replacing the ball joints upper and lower
Don't throw parts at it. 2/3 of my thread was people arguing about how steering stabilizers don't cause DW (they don't, but it seems they can). So you can't trust reviews. Get your tires balanced.
I ended up having to go to Discount Tire to get a proper balance. Lifting just changes everything, and tire issues are one of the main (arguably the main) instigators of DW. Advice from me, which was courtesy of Jerry.
Ill do the dry test, I know my bushings on my upper are worn out i replaced my lower control arms and all my ball joints have holes in the jacket(?)
Upper bushings will 100% cause DW. Especially immediately after a lift (steering angles and caster change). If the ball joint boots are torn, they could be worn out too. Dirt will get in there and wear them out quickly as the grease is contaminated over time. Jack it up, put a long crowbar under the tire, and lift up and down fairly hard. Look for play in the ball joints. Having a second set of hands or even setting your phone up while you crank on the crowbar helps.
If you already found play, that's part of or the sole cause. It doesn't take much of anything to start DW on a SFA rig.
Ill get my upper control arms replaced, and check for the play on the wheels thank you
We don't know. You need to do a dry steering test with the Jeep running on the ground (have someone steer 10 to 2 back and forth). Look for any side to side movement. Check your torque specs. Check your ball joints by raising one tire and wedging a lever under it and seeing how much play you have. You should have no side to side. Some up and down is ok. It's a process. Check your alignment. YOu should be toed in 1/16-1/8" at 24". See the align your own TJ resource. Check your tire balance because that is a DW trigger.
