***YES I KNOW WHAT DEATH WOBBLE IS AND NO IT'S NOT A TIRE SHIMMY***
So to start, I have an 06 LJ that I bought with a 2" puck lift that had a very very occasional death wobble only at highway speeds. Didn't worry about it because it was rare. Happened 3 times total maybe. only non-stock things were the lift pucks and shocks. I bought a 3.5" used lift that came off a buddys TJ. included used skyjacker shocks, springs, adjustable front and rear track bar. I bought new extended swap bar end links. I got some used rough country adjustable control arms and replaced all the bushings before installing them and then got an alignment. The alignment helped a bunch but they showed me the ball joints were bad as well as the drag link (i did the ZJ tie rod conversion so the tie rod was good). I replaced the ball joints and drag link and it didn't really help. I then replaced the front track bar with a metalcloak one, still didn't help. I balanced the tires (goodyear MTR's 33s) and one was pretty bad calling for a 10oz weight. I still managed to balance the tires to 0. Before balancing my jeep would always get tire wobbles that would send it into DW at about 50-55 mph. After balancing that went away but I still get death wobble when going over certain bumps. So to sum it up I have a new track bar, new sway bar end links, new tie rod and drag link, new steering stabilizer, and new ball joints. Used control arms with new bushings and used coils and shocks. What else can cause death wobble besides the wheel bearings. Myself and 2 other people have checked the wheel bearings and they are fine. I need help!!!!
