Assuming you're set up well on short arms already, the pinion angle shouldn't change much if at all, though - right? And the arc of axle movement is shallower. I suppose unless the arm separation is enough to roll the axle a lot more.
It moves a little, so if you're looking for perfection it needs to be considered. I copied the PP towers and lower shock mounts and made my own for the front. So if we need can some up that's not a problem.
