Winch clutch slipping?
red02tj
TJ Expert
Atlanta
my new to me 9.5.
Installed the new winch plate and went to tension the line. While in free spool, I can pull out the line by hand, but if I engage the motor, the winch drum will spin both in and out.
If hold the line while in free spool and engage the motor to bring the line in, I can easily hold the line and the drum will free spin.
Also looks like a decent amount of wiggle in the clutch lever. Ive run the line in/out about 5 times and same thing.
Should the clutch fully disengage?
Lever https://share.icloud.com/photos/075JUeZ99oYsZfuZNdzYpQOiA
Not real clear on what it is doing. With in free spool the motor will just spin, as it sounds as if it is doing. With it engaged does it wind in and out ??
The teeth may be stripped inside the gear housing. Only way to tell is take the gear housing apart and see what is messed up. Good to clean and regrease anyway.
https://www.rocketcityrockcrawlers.com/forum/_topic11377.html ?? Help ?
I spoke to Warn and showed them the video.
It appears the brake is dragging, in free spin. The drum will still rotate, but lightly enough I can easily hold the line while winching in and break tension. I didn't hear any gears grinding.
Yep, and appears the brake holds.
They suggested I order the 82463 Lever Midframe kit for a new clutch lever washer and set screw. I also ordered some AeroShell Grease 64. Looks like I'll start with pulling and greasing the gears, new o ring, set screw and go from there.
Reactions: John Cooper
Waiting on parts and grease so I started cleanup. Some buildup and a touch of surface rust on the sliding ring gear, but overall looks pretty good.
Based on how this looks, keep tearing down, or just finish cleaning the gears and repack?
You've got it torn down this far, you're almost there. I'd completely tear it down, there may be other "surprises" awaiting, or even if not, you'll have it all cleaned up and know what you have. Its not that hard to do...
Reactions: red02tj and sab
Gearbox assembly vid for reference
Brings back memories. At first I thought you'd forgotten the little sun gear, but upon a replay, saw you install it after all.
Now you get to do it again after greasing everything!
Thats my reference video….but I did follow along to test. Just waiting on my grease delivery.
is the new style lever supposed to fit the older 9.5 series? The groove where the set screw rides is in the opposite direction, wanting the lever to rotate towards the winch and it can’t clear the housing, vs the old style which rotates out.
Either way, I like the old style better and it will cleanup just fine.
  • USA Proud
Old lever cleaned up nice.
Got the gearbox assembled and did a no tensions spool of the line all the way in. Gears didn’t explode and no strange noises.
FWIW there is still a bit of friction when I have it in free spool and a use the motor but the gears are cleaned and freshly greased. Motor side for another weekend.
@Blackjack @tnjeepguy got one for you guys before try and respool my line with some load on it after my clean and regrease.
The clutch lever will goto freespool first try every time. When moving to engage, the lever moves easily but sometimes I need rotate the drum, kinda like backlash, before it engages. Once engaged, it powers in/out without issue.
