Ok not looking for 44psi pump as it seems 49.2 psi is standard operating pressure give or take 5psi. My current one runs at just about 44psi steady if accelerating or just idling. 1999TJ with fresh 4.0 and seems to be running lean as after break in swapped plugs and after a few hundred miles plugs are still pure white. My check valves do not seem to be doing their job as psi drops after shut down a few minutes so going too replace pump but best I can find is 44psi max
Thanks much
Thanks much
