Sometimes I get extended crank times with my Jeep, which has been getting worse lately. It also has a hesitation to rev when I first start it. Sometimes it will hesitate under load as well. So today I tested the fuel pressure, and it is a perfect 49 PSI when running. However, I have to turn the key on three times to get it up to 49 PSI before starting it. It's like the fuel pump doesn't want to run when the vehicle isn't running. The pressure also drops immediately to about 5 psi and then gradually down to zero after shutting it off. Is this likely to be my check valve, fuel pump, or something else in the system?
