Good afternoon from the UK!
Ive had this problem with my 2002 Jeep TJ for a while where the speedometer gauge doesn't work, while all the other gauges work fine. I gave the gauge cluster a test (the test where you turn the ignition 3 times while holding the trip button) and the speedo gauge moved about fine.
After looking online, i was led to believe that it was the speed sensor (on the transfer box) that was causing issues. After plugging in my obd2 reader, and driving about, i was getting an accurate speed reading from the readers screen.
From this i thought that it might be a connection issue, though there seems to be no visual probelems with the cluster connectors or wires. One thing thats preventing me from further inspection, is that i cannot find a pinout online for the 16 pin connector that i believe carries the speedo information.
Does anyone have an idea of the problem and/or have a pinout for this 16 pin connector?
many thanks, Sonny
many thanks, Sonny
