I pulled this HP Dana 30 from a Yj. It has the CAD unit. Guy I got it from said that the previous owner got rid of the 2 piece passenger axle shaft and installed a solid shaft from an XJ. I was please to find that to be true.
Since it came from a leaf spring jeep, I figured I’d throw a truss kit on it to help locate all the necessary brackets. In doing so I had to further delete the CAD box.
Next was a Torq Locker. I was pleased to find all the gears and such in great condition! Locker is in. I did have a terrible scare! Broke one of the ring gear bolts off, when trying to reassemble. Praise God. I was able to back it out enough to expose the fracture before the head spin off. Grabbed the broken nub with pliers and spun it out! Thank you Lord!
With the carrier out, new seals are next. This is where the head scratching begins. Perhaps I overlooked somethingIn my research of the HP unit. The long side has a different seal than the short side. Also, there appears to be some sort of soft rubbery gasket surrounding both seal. Almost seem as though the seals are both seated within this red gasket then pressed into place. Any and all info is appreciated.
