I've been seriously distracted by another non-Jeep-related project at the sab homestead lately, but I feel like it's important to make a little progress on the LJ build every weekend. I had about six hours today to work on the LJ. The first LJ-related project was to fix a small issue with the Atlas twin sticks. After I assembled the interior, I discovered that the rubber boot for the front axle sat too high - the top of the boot would pop up through the console slot. This would cause it to bind a bit on the front console slot. The solution (I hope - time will tell) was to put zip ties on the tops of the boots to hold them down:
Next, I started cleaning up the wiring around the transmission and transfer case. I bought the Rubicon control box for the Atlas four-speed, and the control box needed a home, so I made an aluminum bracket for it that mounts to the top bolt for the clutch slave cylinder:
And then I mounted the control box:
The purpose of that control box is to manage the Low and 4WD lights on the dash. I also have to wire in the microswitch for the Atlas four-speed planetary shifter, as well as wire in the power to the control box, and find a place (preferably in the cab) for the Speedohealer.
Stay tuned...
Stay tuned...
