This is why I hate NSG transmissions
Anyone ever overhaul one of these transmissions? Is it one of those that the gears have to be pressed on the shafts, or is it a more conventional assembly method?
Yes, there is a guy who rebuilt one, requires a special tool to assemble. He posted videos.
Anther one is fucked, 4th howls under load, 3rd grinds when down shifting, and 5 and 6th are noisy. Not as bad as fourth. Need to adjust pinion angle on the back and the steering wheel is now a little off, handles great in corners.
Need to figure out the pinion angle, right now at 0.1, maybe tilt down more to .5-1.0 degrees. Don’t think it’s the front, didn’t feel it in the steering wheel. Vibration is significantly higher at 50-55 mph. Right front tire needs balancing too. A few more bugs and maybe I can try highway? Doubt it. Might convert to a 435, bell from Novak is 500 and the tail shaft kit is 600 from AA.
Reactions: ColoJeep
Makes you wonder how they ever built these transmissions in the first place. Sorry. This sucks. What’s your next step?
Reactions: ColoJeep
Call zumbrota and ask? Put on 100 miles, just a dirt road and a 2 lane highway. Did get 11.7 mpg and that’s ok since the roads were in mountains
I would be so f'ing discouraged and pissed. Sorry. That really sucks.
Zumbrota said to send it back, they want to look at it. So I hope that this is the last one. Its not like I can screw this up, is a bolt in replacement with a new clutch and a known atlas that I had in another jeep. Everything worked great up until it didnt.
Reactions: ColoJeep
adjusted driveline angles and got it through emissions and safety inspection. I I am at 1 degree nose down on the rear pinion from driveshaft angle one degree up on the front. I need to go a bit more to get it to stop vibrations at 50-70 mph. `220 miles on this transmission and 3rd syncro definitely has a problem, was only grinding downshifting from 4th, now up from second too, not even fast shifts, just a smooth shift.
Took the rear shaft to 3 degrees at ride height and it has less vibration, at full droop it has 5-6, if I fill the tank, put the back seat in I think it will be right at 2. I am going to pull the front shaft to make sure it’s good. I actually like the way the jeep drives and handles. The Durango calipers will lock up the 33’s if I have to panic stop. The atlas is working great. Almost 220 miles on it. 3rd syncro is toast, so almost there. I want to finish dialing in as much as possible before I yank it again.
Am I right assuming you still have the most recent NSG370 installed?
I did a bit of digging online. I found a couple or three outfits that claim to rebuild NSG370s that I don't recall hearing about them here. Wonder if any of them are any good...
At this point, I don't think I would trust anyone with rebuilding a NSG370. I asked a very reputable trans shop by me, and the owner kind of laughed.
Mine has had a bearing whine and vibration for the past year or so, as much as I like my 6 speed, I think I'll be doing an AX15 swap.
I did find someone on F***book marketplace that has a brand-new factory NSG370 from a 4cylinder TJ. I was thinking about attempting to swap the front case half on. However, $1800.00 is a bit much on a gamble to see if it fits.
Yes William, I see wrecking yard 6 speeds for that price and have yet to gamble that much money and work.
