Hello everyone,
I am looking for some guidance regarding a problem I am dealing with related to my TJ.
I have a 2003 TJ Rubicon with 31K miles and the 42RLE auto transmission. About a month ago it started idling really rough and driving like it was running on 2 cylinders. It threw a P0325 code.
Since that time I have replaced the spark plugs, ignition coil and the crank position sensor (from Mopar). This has had no effect.
I have checked engine compression and it is perfect. I have also traced all of the wiring from the coil to the PCM and found no holes or exposed wires there or anywhere else in the wiring.
I am not sure where to go next. Any guidance would be much appreciated. Thank you
