CEL came on today with P0351, intermittent circuit interruption on primary coil A. I had this code along with P0352 and P0353 about two weeks ago and my jeep was misfiring. I have since then replaced a number of parts all mopar including my crank and cam shaft position sensor. All the codes I had went away and the jeep was running like a champ for the 150 or so miles I had drove it, until today when the light came on Still no performance issues but I drove it straight home after the light came on and here I am. I am thinking the coil rail that I bought turned out to be a dud, but not sure. The wiring harness visually appears to be fine. Other than it being a rail or wiring problem, the only other thing it could be is my ECM. Where do you guys think I should go from here?
