What do I need to install rear defrost switch on my 1999 TJ?
Update:
Found my wiper wiring schematic, it should be clear enough to follow 😂 Note the C326 is the connector at the harness. The pin # callouts refer to the pin on the switch
I was able to successfully add my own wiring for rear defrost and rear wiper. I created a how to thread for the defrost, looks like I didn’t get to uploading the wiper portion. The wiper is simple, pretty much have a 12V hot always to it, this is for the park position I believe. Then there’s a wire for the wiper motor, and the second momentary position is for the motor + wiper fluid, here it is below:
How-to rear defrost
Thank you very much for your response and help! I'm not good with a lot of these forums. Sorry:( I didn't know you responded. I don't know if you are allowed to do this here or not. My email is davestierle08096@yahoo.com. Any info you have or recommend would be very much appricheted! In return, I have accesses to some of the aftermarket programs to look info up. If you need some info I will try to help. I'm going to look at the link you sent me. Thanks. Where does that harness go into the cab up front? I have a used harness and some parts. I don't care that I poset this info email. I will try to help anyone I can to a degree. I cant abuse it. Thanks.
Reactions: Duner
It depends on a few things. If your harness has the plugs for your switches in the center dash bezel, you’d probably be better off trying to source a complete rear section of the harness. It’s not a hard swap.
If you don’t have the harness for the switches, you’ll have be more creative. That’s what I had to do, wired in my own fuse relay box and mocked the circuit.
How-to rear defrost
Thanks again! That is some solid info! Mine is a 99 TJ so some of the wiring is there in the dash, and at the PDB under the hood. I also have an after market connector for the hard top if needed too. I'll let you know how I make out. I'll try to remember to take some picks too.
Reactions: Duner
