2004 4.0 I6 automatic Dana 44 with limited slip.
I had recently been diagnosing a clicking noise from the rear end of my TJ. While investigating I found that there was a chunk missing from on of the teeth on the spider gears. Also the clutch pack was pretty worn. I read they are only really good for 50k. Will be looking at swapping to the trutrack when I rehear down the road.
The changeout of the gears and clutch packs went well. I soaked the packs in lsd additive over night before the install. I also replaced the axle shafts and bearings along with this work.
I now have a whining coming from the rear when coasting in 2nd gear or so. At least it’s most noticeable then. I don’t have it when the rear end is under load.
So here is my thinking/ questions. So I have the carrier bearings or pinion bearings need changed. They were fine before so I wouldn’t think it’s them. The carrier bearings looked good when I did the spider gears. I did not remove the pinion bearings. With that said I was under the impression that I did not need to mess with preload or meshing. Maybe I missed that when researching the job.
Any direction or advice is greatly appreciated!
