99 TJ 4.0 engine misfiring
mikekirk9020
Grants Pass
At my wits end. 99 TJ 4.0. Engine misses at idle and seems to smooth out at higher RPM. Have replaced and checked, rotor, cap, wires, plugs and finally injectors. Did not drop the money on the injectors until I checked signal coming through the wires to them. Some.of them were OE and corroded so no big loss. Fuel rail pressure was right on the money.
Engine missing on #3 and #4. Throwing p0303 and 4 codes.
Next ideas are MAP and possibly Coil.
Other thoughts?? Help?
First I would Do a complete compression test
I wonder why the 2000-2002 were crap?i didn’t spend a dime on mine when it started missing,i just found a rebuilt tupy and all is good.
TUPY 0331 heads seem fine , other 0331 heads were too thin in some areas.
