31s finally gave up on me. Sidewall just cracked while driving down the road. Pulled the trigger on a set of 33x10.5x15s.
I'm still on my 3.73 factory gearing behind an AX15 5spd. Dana 30 front, 44 rear. General consensus seems to be that I want 4.56 or 4.88 gearing for that combo. I tow a ~1,500 lb trailer often, so I'm opting to go the deeper route.
Can someone point me in the direction of which kits I should be considering? I believe I need thick cut gears for at least the rear, and from lurking in another thread recently, I've learned that Revolution seems to be the only manufacturer I should be considering (Yukon no bueno).
