Bought Another LJR Because I Have Poor Impulse Control (Again) - 37's on Stock Axles
So I should be asking for a stripping then? I’m just not familiar enough with the process and don’t won’t wind up with something splotchy because I gave bad instruction.
Ideal outcome would be to bring this armor back to raw aluminum and finish in a way that looks decent. I like the look of what @taylormade73 posted earlier in this thread.
I was moving away from that after hearing that it won’t be something uniform I could work with. For simplicity sake I’m considering just going black, but don’t want a splotchy finish like is currently present.
We powder in house. Recently we had a major issue with a bunch of PL1/4 x 5' x 12' sheets of 5052 that had been hung on the outside of a 19 story office building. About 60 sheets total, laser cut in a "artistic" pattern. Had some adhesion issues, and we needed to strip all the panels and do it again.
Our options were bead blast or recut. Probably 2.5 - 3 hrs to blast each panel. We found someone local that put them in an oven at 600 degrees and burnt the coating off in five minutes. Cost us $20 per panel.
Now we just needed to wash and recoat. I don't if that would be an option for you, but I can run down some info on what they do regularly. Maybe find someone local to you with a similar set up.
This is one of the reworked panels. The burn-off was clean - if you wanted to re-grain it would be quick work.
Reactions: Apparition and NJW
Dang. That sounds like it could be worthwhile to look into. I'm in Southern Colorado, the armor is at my powder coater in Pueblo. Waiting on a few more pieces I ordered over Black Friday.
