Today's entry is an update on the center console insert project. As mentioned in the previous post on the subject, I had some revisions to do in order to clear everything else occupying space inside the console. Those items are the subwoofer, the step slider control module, and the cutting brake handles in the fully-engaged positions. If anyone reading this has made a complicated model in Fusion before, you know the dread you face when you want to make changes and know that you'll be presented with many errors as references break and you have to slowly work through the part history fixing things. Well, it took me all evening to work through all of that, and at about 9pm, I started a test print of this latest design:
Since my last test print in PETG HF was a disaster using the PLA/PETG support at the interfaces, I decided to switch back to PLA and the PLA support filament because I've had much better luck with clean, easy separation between the base material and the support material using that combination. I also went to .24mm layer thickness for a quicker print and because @Mike_H discovered that layer thickness affects support removal, and thick layers are easier to remove support. Here's a picture on the print bed just before I removed it:
And this is how support with the support filament at the interface is supposed to work (look closely, and you'll see the layer of white support material on the supports on the right below):
Nice and clean, and easily done! Sadly, I'm not sure if it's the layer thickness, the change in materials, or something else that did the trick. But I'll take it!
Here are pictures of the top and bottom of the console with everything installed:
I have a bit more tweaking to do. I fixed all the clearance issues, but the interface with the top opening on the console is too tight. I'll have to do more battle with broken references in Fusion to get more clearance before I print the final piece - hopefully very soon! I also made a little more progress on a model for the slot dust covers. Stay tuned...
Looks great! Glad you had some success. Let us know how the Support for ABS turns out. The TDS says its HIPS and I have a roll of that for supporting my tail light housings. Haven't played around with that too much, since I've revised it to a point that the support is kind of a non-issue now...but cleaner removal is always welcomed.
