I've been having an intermittent cylinder 4 misfire that became perminate on a trail at Windrock this past Friday. So, since I had a spare ignition coil and injectors I swapped them out without any change. I went to the parts store and picked up new plugs (6) and put them in. The Jeep fired right up and ran good for a bit. I shut it off and let it set for a couple of hours. When I started it again, it had the misfire and dumping fuel out the exhaust. I got home late last night so this morning I pulled the #4 spark plug and it was wet with fuel. If I pull the #4 injector plug off, it smooths out the engine.
The coolant looks fine with no contamination. The head doesn't look cracked or have goop inside the oil fill cap looking down into the head. I'm almost 100% confident it isn't the 0331 head crack.
Any ideas what else this could be?
