Finally planning to remove the outer axle tube seals (do I need to run the oil slinger?)
Moglocker
TJ Expert
St.Augustine,florida
I am finally going to remove the aftermarket outer axle tube end seals on my Dana 30)I should not have used them on it when I did the regear.i think they do more harm than good.i am running the revolution lifetime shafts with the jk joints,should i use the factory plastic oil slingers,will they even fit on these shafts?thanks-jeff
https://www.jegs.com/i/Crown-Automo...sZLuh9h8Bho1pkSeJSzKNG1_5IkKOQoXXewy5UB6pGv_m
The RG&A shafts are larger in diameter so the stock plastic cover won't fit. FWIW, my tube ends have been open since 2019.
  • USA Proud
Reactions: lBasket
Since you cant run em and ever worry about mud or dirt getting in there you can flex your jeep or place a jackstand on one side of the axle and set the garden hose thing on "jet" mode or whatever to get the mud out, Ive had to do that a few times when i've unfortunately hit mud
Reactions: Moglocker
