Specs don’t matter. How much uptravel you have and your travel bias matters. A lot of the issue could be too long of shocks and incorrect bumpstop length.
This
At the rate I am seeing people complaining about Bilstein shock you would think I could be able to scoop them up for cheap.
I would point the fingers at the shocks but won’t pass judgement until I see the entire suspension set up. Could be a lot to address. Can you post some good photos of the set up? Bump stops, track bar, control arms and the works?
Skyjacker Blackmax or Rancho 5000X. Make sure they’re the right length so your travel bias is 50:50. Definitely not Bilstein 5100’s. Get a new builder if he’s questioning springs. Tire pressure at 24-26.5psi. Go have fun.
That's what people keep saying but these are the specs RK sent when I questioned them. Haven't measured but I netted more than 3-3.5 inches.
Bump stops haven't been touched yet sway bars haven't been disconnected either and I've hit some speed bumps at speed and done some mild flexing around the yard to make sure everything is settled. Nothing close to full stuff in each corner though.
It does not matter what RK sent. These springs resulted in the ride height you have right now. Measure the shocks at the current ride height and figure out what the travel bias is.
I've only ever heard people complain about bilstein's in reference to TJ's and LJ's. It's a quality shock I think it's just meant for harder hits than what I'm giving it because above 55 mph the soak up bumps really well. I think with a much heavier rig, armor, axle combo, they would behave differently.
To be clear even Bilstein 5100s at the correct ride bias would still be stiff yes or no?
You really really need to cycle the suspension without the springs to check the bump stops. Plus everything else folks are suggesting.
Otherwise you might smash in your oil pan...I have lots of videos of me trying to half ass this process and learning the hard way.
Don't you dare try to apply logic within the realm of Jeeps lol!Walmart has a spray paint Aisle and the red boots are optional, and typically not recommended as they trap debris. Shock color should not come before shock quality and how that translates to drivability and comfort
Do my measurements sound close to you?
You're the only one who can answer that question. You need to know your extended shock length and the length between the upper and lower shock mounting locations.
To rephrase, half of the shiny shock shaft should be exposed at the normal ride height. That is the 50/50 travel bias we are looking for.
Thanks for speaking "Crayola Crayon" because from my motocross experience, suspension may as well be unicorn farts and fairy dust cus I can't grasp all of it but I know I need it so I let someone more experienced than me do the math. I confident that I can measure the shiny part!
Appreciate it!
To be clear, this goat will never see full flex. Maybe a little light trail use but I have a "trail' TJ for playing. This my air conditioned, daily driver. I found it on the dealership lot that it was bought from by the first owner, on the stock suspension. Almost unmolested but never kept in a garage. I'm trying to get the best ride within reason for a 20 year old wagon with solid front and rear axles and a tractor motor! SW Florida doesn't have the terrain to challenge it but there's an awful lot of flooding in the rainy season so the lift and 33s made sense.
