High mount brake light: what lamp?
Reactions: Zorba
OEM PN: 55055 280AB
The manufactures PN: 921
While your referenced part states it replaces the 921 and the base may fit into the lights receptacle; I have found that the dimensions of some LEDs do not fit inside the enclosure.
You will need to verify that.
Here is a source that I use for most of my LEDs.
https://www.superbrightleds.com/vehicle?find=2000-jeep-tj-5405431&sid=WjwyyVlVRF
Thanks, I was hoping to get a flashing one since I've been rear ended once and almost again yesterday. For some reason people like to follow behind me really close in the TJ.
I went ahead and ordered it, I just watched the video and it shows one installed and working in a TJ.
I dunno if they make LED bulbs that flash or not, but these little modules are readily available:
View attachment 672359View attachment 672361
Several years ago I removed the high mount brake light and replaced it with a LED ring behind the spare tire and the LED brake lights.
It's quite bright at night and gets other drivers attention.
Reactions: Zorba
