Darnit, you two are going to get me to spend more money...
You should already have a space mouse. It’s very handy especially with your back ground.
I’ve had them all from the puck version (cheapest) to the one like Jeff’s. The screen can be handy for setting up different functions and if you’re spending days modeling I’d recommend it but the mid tier one is almost as useful.
Haven't gotten too far into the mouse. It was a package deal with the Enterprise. It is a nice, 5-button + wheel programmable version, and is a bit bigger and heavier than the mouse it replaces. "It feels nice" is about all I can say about it at this point...
In my design career, I never used anything other than a mouse, if you can believe that. I've never been exposed to any other type of input device...
Same here. Though I have been exposed to other devices, I've never found any of them to improve workflow or increase productivity for me. I've always gone back to the mouse in the end. Left hand works the keyboard, right hand on the mouse...both devices show very interesting wear patterns after a year or so.
Currently, the early Logitech MX Master 2S (non BT) is my go-to, good battery life, fast tracking, decent weight and fits my mitt. Basic button functions, don't even load Logitech's special drivers for unneeded extra features. Most mice are entirely too small for "properly sized human hands".![]()
I'm new to this and was using this as a learning tool. Adding oil was always messy. It is less so now.
I found a model that screws on, then added a funnel.
View attachment 671071View attachment 671072
I need one of those
Oh man, that's cool.
Is that like a 4-banger version of the AMS HT? Does it also do active humidity control? I think mine just monitors humidity and has a few packets of desiccant in there for good measure - but not sure.
Edit: Took a look and my questions are answered. Again - That's very cool. Let us know how it works for you, Ryan.
Anyone want to help me modify a stl? Going insane trying todo on my laptop trackpad.
This is a 4 way X divider for the 4in packout bins but I’d like to to just be halves. I can remove two of the legs but can’t get the center infill right so that it’s a solid piece across
Try this. I don't know if you were working in Fusion, but that's what I work in. I provided the Fusion file, too, so you can look at the history to see what I did. You may not have realized that you need to convert the mesh to a solid. STL files are hollow, so if you modify them, you leave holes in them. Convert to a solid, first, then modify and save as an STL.
I also work in inches, not mm. When opened your file, the divider was 31" or so tall, so I scaled by dividing by 25.4. When you open it, you may need to scale it back up to mm using a scale factor of 25.4. If you have trouble with this file, PM your mobile number and I'll call you to walk you through it.
Very close.Try this. I don't know if you were working in Fusion, but that's what I work in. I provided the Fusion file, too, so you can look at the history to see what I did. You may not have realized that you need to convert the mesh to a solid. STL files are hollow, so if you modify them, you leave holes in them. Convert to a solid, first, then modify and save as an STL.
I also work in inches, not mm. When I opened your file, the divider was 31" or so tall, so I scaled by dividing by 25.4. When you open it, you may need to scale it back up to mm using a scale factor of 25.4. If you have trouble with this file, PM your mobile number and I'll call you to walk you through it.
