Ok so,
I know long arm setups aren't the preferred route here. I picked up my jeep a while back and it had the rough country bolt on long arm kit with Johnny joints swapped on.
I've read quite a bit about these having too much antisquat, resulting in hopping when climbing. As far as I'm aware, the position of the end links on the frame side adjust this, and being as the frame side joints for the upper and lower arms for the rear are level, this results in higher antisquat.
I have some weld-on brackets that the po gave me, which would eliminate the bolt-on portion and give me an extra inch of clearance on the skidplate. The brackets also position one of the end links higher in the rear. Theoretically this should lower the antisquat, right? Just trying to decide if its worth the time to install, or just continue running the setup as is.
