Hi all,
Had the typical belt squeal recently. Belt wasn't in the best condition so assumed that was the issue. Since then, I've replaced the belt (Dayco) - correct size, the idler pulley, and the tensioner and it's still squealing. Alignment looks fine, tension is good, I cleaned all the grove pulleys and no luck. Pretty sure it's a slippage issue, because the water trick kills the noise instantly until it dries out. But after all my research, I'm at a bit of a loss as to what else it could be.
It starts at idle, and gets faster as your rev - but not louder. Nothing I change on the dash from an electrical or aircon standpoint change anything and all the pulleys spin fine by hand when the belt isn't on.
Any thoughts to narrow down what the issue could be would be a great help!
A video of it if it's useful:
View: %5BURL%5Dhttps://youtu.be/gte1J9gx_4E[/URL]
