I predict it acts the same because your TPS voltage checked out fine with both. Unless, again, the problem is intermittent. Don't forget to look at the TPS voltage when the problem is occurring. Let it idle, check the voltage, and then give it a bit of throttle and see if it rises smoothly, followed by falling smoothly as you slowly let off. Once you do that, you can completely rule the TPS out.
I've never had my TPS off, so I have no idea if there's supposed to be an o-ring there. However, it making the throttle stick makes perfect sense if it wasn't supposed to be there. When you tighten it down, the o-ring's I.D. decreases as it is pinched, causing drag on the shaft. It doesn't take much to make a throttle stick. The friction in the system is carefully kept minimal and the return spring is purposely weak - so you're foot doesn't get tired holding the throttle open.
