We did a ton of testing, built cool machines, made entire clear steering systems, killed a bunch of pumps, made a huge mess over and over and over. It was an amazing time to be alive.
We tested pressure and temps on both sides of coolers, and all throughout the systems.
Unfortunately, most cooler brands don't advertise pressure drop, sillier than that, most are rated by the amount you tow, your steering likely doesn't care nor is it affected. I'm convinced Universal means transmission or engine oil. The low-pressure side (Cooling circuits) see maybe 50 psi on a transmission and maybe 15 psi on a motor, seen spikes over 400 in steering systems. The flow rates are similar in the transmission, engine and power steering systems 2-8 gallons a minute. One would also have to keep in mind that the term steering system is a little too broad to have one sword with which to slay every dragon. Today we will talk about systems with steering gears for the valve, engine driven pumps for the pumps, and some sort of cooler. If anyone has questions about full hydro set ups or race car goodies reach out any time.
There are exceptions to everything. Guys have been running transmission coolers forever and had success. Plenty of them have exploded, plenty of them have caused terminal pump failures "but I have a cooler on it". This info doesn't help as there isn't any way to quantify which cooler works and which doesn't when there's no agreed upon specs to measure them by when using them in a steering system.
There are some good rules of thumb and some things to think about that can help you make a steering system work well and live a long life, and each part and it's installation have as much to do with it as the cooler, less though, if it's a good flowing quality cooler.
Log style, extrusion style, heat sink, whatever they call them where you live, are super popular for steering systems with good reason.
1. They are stout, the material is typically thick and due to the nature of their construction they handle higher pressure well.
2. The smallest hole in the cooler is the one the fluid is coming in through and exiting through, the rest of the column is larger, this causes the least amount of drop and restriction.
3. Volume, a rarely thought of but valuable tool in cooling anything, the 14 in extrusions we used to us add about a qt to the system, that's huge when you are starting off with 2-2.5 qts.
Those aren't the only style, stacked plates, tube and fin, and tube and Plate can all be made to work, but they aren't all made the same.
1. If the tube that runs through the fins is smaller than the inlet/outlet, it is restrictive. (Tube and Fin)
2. If the Plates are crimped tightly (whether it's the end or cap or the entire capillary) then the entire path of the fluid is smaller than the inlet and out let, this is restrictive, some are constructed where this is real bad, others have larger volumes, it's difficult to know without cutting them apart.
3. Many of these coolers are made from very thin material, and as we have spoken, the crimped method they are constructed with is not better with thinner material.
4. The racing aftermarket has come in and made some radiator-style coolers with billet tanks, thick wall tubing for the inner tubes, well-spaced fins with huge areas to weld them together so they stay together. These things make me happy, I love using them, they are difficult to package, have their own fans and you could even mount one of these heat slayers improperly to the point that it puts heat into the system.
Installation matters, all coolers are heat exchangers, the temperature outside fighting the temperature inside. This also applies to the reservoirs, which is in its own right an exchanger. If the temperature of the air outside your cooler, even if it's being forced through it or around it (This is usually worse) is higher than the temperature inside of the cooler, you are adding heat to the system. I must also say don't make your cooler an air trap, it will fill up with air and not fluid and cool nothing, in the bottom out the top, all out the top or all on the side if its horizontal.
Sorry to drone on about this, I have been on trial about power steering pumps most of my adult life and if this helps one person, it was all worth it.
LG
LG
